Here you go. Did mine last time I had the roof off to clean everything which was last spring... I used foil-bubble-foil Reflectix and glued it on with 3M spray contact cement. Coated both the roof and the Reflectix with cement, let it tack up and stuck it on. Have to cut it to fit first. I remove my roof every year and clean the underside and wash or replace the cabin air filter. I use both mine (I have a pair) for running hay so I get a lot of fine chaff up there. I also make sure my ac if fully charged and keep the rad and all the heat exchangers clean (AC and turbo air to air units). This last year I also had to fiberglass a couple of the rivnuts in the roof as the roof was cracking around them so I glassed them in and this last year I also replaced the perimeter gasket and the 4 spacer pads as my ld ones had lost their spongy (for lack of a better word) resilience, In other words they lost their springiness. A quick hundred bucks at your local, friendly Kubota dealer...lol
Made a huge difference in cooling ability in the sun.
I might add that I also added a 12 volt automotive cooling fan in front of the ac underhood heat exchanger wired to the ac compressor with a relay so when the electric clutch on the ac compressor is energized, the cooling fan is also running, pushing air through the ac heat exchanger. Really a benefit when the tractor is idling and airflow is less than when throttled up. She's ice cold all the time now. I have the factory tint on my windows and with my mods, it's plenty enough.
