Correct.
Whether a BX should have a skid plate option, or if the fan system or the filter should be relocated are other, ancillary issues and while important issues, not identical to the point of this particular thread.
A parallel thread on the HST protector has received almost 6000 hits. One might suggest that there exists considerable interest in this.
While retro fitters still wait.
I agree, relocation of the vitals is also not the issue of this thread nor were they mentioned in my reply either.
The point of this thread, if I understand correctly, is a call to arms by BX owners to solicit Kubota into offering a so-called superior fan protector at a reduced price for all BX's that I contend is no "practical" fan protector at all. And since input was solicited regarding this issue, my input was why not take it to a higher level and request "actual" protection for a BX setup to operate in either a TLB or ground engagement type scenerio where keeping the MMM on either impedes the task and/or causes the MMM to be "knocked" out of level.
The OP should be commended (as he was btw) for bringing to light that Kubota made a mid-production manufacturing change to the BX. I'm sure Kubota has in it's fine print somewhere that these changes can be made at their discretion at any time and although it appears to be backwards compatable, it is by no means a requirement for Kubota to provide this for BX models that were manufactured previous to this upgrade.
Kubota certainly opened up a can-o-worms with the seat recall, but I'm sure both Kubota and the dealers made some $$$'s with an obvious upgrade over the OEM seat as BX owners such as myself that were in no way covered by the exchange program opted to purchase these seats once the offerers had honored those effected by the recall.
In this case the seat was a very obvious upgrade where-as this so-called fan protector isn't, IHMO that is
My BX23 has an OEM frame member that connects between the frame rails directly under the HST fan and I'm sure it's purpose was to deflect large debris from contacting the fan also, but from my previous experience operating in a debris scattered environment where I was clearing heavy growth fence rows sans the MMM, that frame member along w/a solid skidplate didn't keep the proverbial wayward stick from making contact to the fan on my BX23 on two separate occasions. Luckily in both cases the sound warned me to stop forward motion and reversing removed the threat and no damage was done.
Again, if one is going to operate their BX in an unfinished debis scattered environment sans the MMM, be advised that this new OEM fan protector will not protect your BX's fan nor HST filter. It barely provides any more protection than the previous OEM offers.
But, if one is very careful and operates their BX sans the MMM is fairly open and non-debris scattered environments, this new offer may be well worth the effort to prod Kubota to make it available for older BX models, which it appears it is, for a cost
