It has been nearly 10 years since I have worked in a Kubota dealer but did spend 12 of my 20+ years as an equipment mechanic working for Kubota dealers. When I left 10 years ago the consensus was to just use UDT, even the Kubota reps. would tell you this off the record. The only time they recommended SUDT was in very cold climates. I have used a lot of different universal tractor hydraulic fluids over the years and have not seen any oil related problems. There are not a lot of BX's in the area either, and personally I have only ever serviced one and that was several years ago. I did some unscientific field testing of SUDT vs. UDT on some B2710's that were in a highly abusive enviroment and having abnormally high HST failures. I could see no difference in failure rate between the 2 oils, but it is very likely that these failures would have been consistent regardless of how superior one oil would have been over the other. The only thing that seemed to slow down the failures was to reduce the abuse. The company bought 50+ HP machines to do most of the work that had done with the smaller machines.
I have never seen Kubota ask for an oil sample for warranty. But I would still use the recommened oil during the warranty period, just in case.
Brian
