4shorts
Elite Member
I stated several times that the only difference between this older BX and the 2013 model was only sheet metal. Correct me if I am wrong and I will apologize
Well lets see, YOU ARE VERY WRONG
The new 2013 BX is now the 70 series and features the following:
- Foldable ROPS. ( The BX you used did not have at the time. )
- Deluxe high back seat with folding arm rests. ( The BX you used did not have at the time. )
- Holigen head lights. ( The BX you used did not have at the time. )
- The pedal layout has changed. The brake is now on the left side of the operators platform giving the operator much more room. ( The BX you used did not have at the time. )
- The new BX has an RPM guage and all new instrumentation. ( The BX you used did not have at the time. )
- cruise control. ( The BX you used did not have at the time. )
- Cup holder
- AC power outlet
- Optional quick change for the FEL. ( The BX you used did not have at the time. )
You mentioned in your video about the location of the Mahindra's radiator. Well here's the reason for Kubotas radiators location:
The BX-Series radiator is positioned in the middle of the tractor rather than the front. So, airflow is taken in from the operator area and pushed towards the front of the hood. This reduces overheating, prevents grass from getting in the radiator grill and helps the operator stay cooler.
Now compare these features to the older BX that's in your video and tell me if its only the sheet metal that different. If your going to use an older Kubota then you should use and older Mahindrea to make a more accurate comparison.
Now do another video using your new Mahindra and the new Kubota BX and then we'll get a true comparison. To be a good salesman you need to know what the competition has out there and its clear you do not know.
