katoranger
L3000DT won\'t start
I have the use of a Kubota L3000DT, but it has a starting problem. It will occasionally start, but there is a problem with either the neutral switch or the keyswitch itself I believe. I was only able to started it once and then it wouldn't start again. If I jump the starter solenoid it just spins the starter, but won't engage the flywheel. I was told that the neutral switch on the high low range has been a problem.
Any help would be appreciated. This tractor has 149 hours.
Thanks, Allen
Thanks, Allen
