Verticaltrx
Veteran Member
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
There are a lot of variables to being able to handle x size disc with y size tractor. Soil type, moisture, disc weight, disc spacing, etc all play an important role. I have a little Leinbach disc that is 6'10" wide and weighs a little under 600lbs, which is pretty light for a disc. My little B3200 can pull it under any conditions in stock trim, but start adding weight and it gets tougher. I generally add another 200lbs to it the first time over in plowed ground, and the B3200 struggles a little if the soil is wet or too sandy, but generally does a good job. My NAA Ford handles it fine even though it is only 2wd.
With that said, I think you have plenty of weight and traction to handle most 6.5' disc harrows. With 32hp on that heavy of a tractor you might not have the power to pull it very fast, but I think it should definitely get the job done.
