SLOBuds
Keuka,
Take the QA hose and connect it to your aftermarket valve stack P port (pump/supply) - you can have as many valves/circuits as needed. The valve(s) must be open center type and able to handle 11 GPM flow at rated engine speed and 3000 PSI rated pressure.
The power beyond (PB) port or the return from the stack then has to be plumbed where the QA hose normally connects on the tractor.
What is the QA hose? There is one hose back there on the stock L35.
OK, a dumb question as I think about it here. Just want to make sure we are talking about the same thing. Does QA mean 'quick attach'?
When you say that it has to handle 11gpm, is it best to buy a valve rated at 11 gpm, or is it just necessary for the valve to handle that at a minimum? Same question for the psi?
Thanks.
I toyed with this a few years back and just couldn't find the time to get the project done. As you say, at least in theory, the project looks straight forward. But there is some thought that needs to go into plumbing all the lines and careful planning about line routings. I recall someone on TBN who measured very carefully more than once and had to re-do the lines because they were fabricated to his specified length, which was wrong.
There are posts that show good places to put the new stack so it doesn't get in your way. Those would be good to review.
I think that someone ran some hard lines, which sounded interesting to me at the time and maybe ends up with a cleaner installation - if you have 3 spools you end up with lots and lots of hose running all over the place. Your L35 looks like it's eating spaghetti.
But one more thing is that after reading all kinds of stuff and talking to a couple of folks, I actually kind of re-evaluated what I needed. This was a process of looking at how I use my L35 and assessing if all 3 valves of a TNT are needed. So I went back and forth but kind of determined that if I took the effort to do one valve I might as well do 3. The valves are not cheap and you might conclude something else.
My L35 is a workhorse. I am a big fan of the TLB series.
