Apologies for the late reply.
Sixdogs-
If you had a cultivator in front of the planter (even though it was was behind the tires, would you still see it the same way? I mean, then there wouldn't be a "cultipacked" area that was being planted into correct? Again, my biggest problem with moving the tires out is the relationship to my Front End Loader.
With your 2 row planter planter set up, aren't you putting down a lot more N? Or, does the earthway put down more per application or are you putting down just as much because you come back on each side of the corn? Regardless of what's going on, looks like you're putting down somewhat more P&K with the earthway correct?
The way you do things in general makes a lot of sense to me! I think you're saying you scaled back and plant in three blocks at different times to keep the whole operation more manageable (not doing too much of the same thing at any one time). At the same time you're able to do it with smaller scale equipment. No preplant fertilizer and only sidedress once..... That's what I've been trying to get my head wrapped around down here. Biggest stumbling block for me was sidedressing without incorporating (other than a hand cultivator and watering in) and the delay of getting what the plants need where they need it. Using the earthway and incorporating at the roots sounds like it could work. I like it.
I have about 12 rows about 350' I can plant about right now (field corn). Thinking I'm going to make that a target. I'm in no hurry to get it all done at the same time so could block it out too. This year because of time constraints, I think I need to just use the earthway or hand stick it and be done with it for seeding also. Shouldn't kill me, my wife, or my boys for one year.
Thanks Again!
Sixdogs-
Thanks Again!
