OP
Neo
- Joined
- Dec 11, 2011
- Messages
- 38
- Location
- Sydney, Australia
- Tractor
- JD L110, MTD Yardman, Toro Wheelhorse 268-H, JD LA120
Hi Jinman,Neo, I don't think the sealing washer will stop your leak. The bolt hole will just fill up with oil and then it will run out at the top around the gasket for the sump. Currently, the oil is leaking around the gasket and running down the bolt to the head. If you seal the head, the oil will just fill the void around the bolt and leak at the joint.
I've had a similar problem on a older B&S engine. It got bad enough that I removed the engine and split it apart. The gasket was broken is about 5 places. It was thin material and vibration seemed to cause the bolts to loosen and then movement of the sump and engine block completely destroyed the gasket. After replacing the gasket and torquing the bolts with new washers, the problem never came back. I think if your engine is just seeping a tiny bit, I'd tolerate it until it got worse. It's a lot of work to remove and split an engine for a tiny leak like that. I can see that it is wetting the frame under the engine, but can't tell how bad the leak is because you've cleaned the area so well.
Yes I have the same thoughts as you but copper washer is cheap so worth a go.
A tea spoon of oil leaks every time the engine cools (I know because I've caught the drips). Doesn't sound like much but with air draft of the engine fan it make dirt sick on the hole one side of the engine which looks disgusting and one the reasons the previous owner sold me it cheap. I hate dirty engines so if the copper washer doesn't work I will go to the effort of removing the engine to fix it.:construction: ... But I'm hoping that someone will come up with a smart trick to get around that. :anyone:
All the best.
Neo
