Carl_NH
Elite Member
- Joined
- Apr 5, 2002
- Messages
- 3,261
- Location
- Coastal NH
- Tractor
- 01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
A less expensive solution is to get a tined thatcher - $100-200 range - every spring I tow one around the yard and it collects the twigs and thatches at the same time. This would also break up the dog poo if you double pass allowing it to break down naturally.
Then after thatching I use the trac vac to lift up the thatch and remaining leaves. Yes, you will get dog poo in the tires but you will with any machine/solution.
Of course if you have bucks to spend and mind set on a sweeper arrangement go for it. Just trying to be realistic and "kis" keep it simple" approach.
Carl
Carl
