In comparing entry level $1500-2000 machines from JD, Cub, Toro, Craftsman, Husqvarna, etc, its pretty much just a matter of choosing what color tractor you want, the working components are all about identical. You get either a Kohler Courage or Briggs Intek engine coupled by a belt to a Hydro-Gear sealed hydrostatic transaxle and another belt going to a mower deck. Everything else is just each maker's own recipe of the same basic ingredients that are, "economy," components. Just pick your color if it's this type of tractor you want. Often times the type of service you get with these machines makes or breaks if the tractor is good or not. During the warranty period Sears will come and fix a Craftsman right at your house, and most JD and CC dealers will pick your tractor up and leave you a loaner. With some of the other brands, you can be left out in the cold or be responsible for transporting the tractor somewhere for repairs.
When you move up the line and compare the medium price range LGT's, things start to change dramatically. For instance a JD X300 and a CC 2542 are quite a bit different beasts that go out of the league of the machines Craftsman makes.
-Fordlords-
