kiotiken
Veteran Member
Yup thats the one.
Okay at least I know what to expect, doesn't look that hard to split at that point, a few bolts. Guess a manual/parts are in order and the time needed to do it then.Yup thats the one.
That's not good news, mine has been dripping for a little while now and I only have 95 hours on the clock, probably around 60 when I first noticed it.
Mine is due for some warrantee work anyway, so I better send some pictures to my deal and make arrangements to get it fixed before the ground dries out and I need the tractor again.
Jason
Glad it is just a o-ring.
It really isn't too bad of a job.
The hardest part for the home mechanic is holding the 2 1/2's up while it is split.
BTI
I found this thread after a long search : http://www.tractorbynet.com/forums/kioti-owning-operating/244056-small-hydro-leak-issue.html is this the one you are referring to?
Says o-ring leaking -- tractor split to replace.
Hey there this is Dingo Man who started that thread. My DK40 had a similar hydro leak. If you search my threads I actually posted a couple pics. Mine also leaked down through an access hole in the mid section. I never learned the cause of mine. After splitting the tractor three times Kioti authorized my dealer to install a brand new hydro pump, and it has not leaked since. They theorized the one of the out flow fiitings on the hydro pump was not machined quite right allowing it to leak even after reading o-rings.
My only suggestion is check your power steering lines up under your steering column. This is what they had me check first, and I know it is quite common on Kiotis that these lines loosen up and leak. I know the DK and CK are probably apples and oranges but that is my story. Good luck.
