CCWKen
Veteran Member
- Joined
- Mar 22, 2005
- Messages
- 1,194
- Location
- South Texas, USA
- Tractor
- Ford-3910, JD-420C, Kenbota-Custom, IH-2606
If you are perhaps refering to the Delco 10SI, 12SI, or CS-130, and the other similar variants, then you are close.. but no cigar.
No soup for you either. Since when does Kobota use Delco? In any case, Wolf is right in that some mfgs. DO wire the charge lamp in series on the ignition lead. Some will have a resistor parallell to the lamp too. In those cases, the resistance of the lamp and/or resistor is required by the alternator. It won't charge without it. When using a LED, you need to add a resistor in series with the LED and use the alternator side of the circuit (I) as negitive for the LED.
