Tibbits
Bronze Member
- Joined
- Aug 19, 2007
- Messages
- 74
- Tractor
- L3430 GST, BX1500
A tire guage for liquid filled tires also helps. You can pick one up at TSC or somewhere. You must have some air in the tire, since liquid does not compress like air you could blow a tire out if you hit a bump or hole. You definately need to make sure you have some air in each tire.
My fronts are filled too, but do not need to be. Its probably extra stress on the front axle but I am not going to worry about it unless one goes flat. It probably adds a little stability on slopes.
I tend to run about 10 psi for smoother ride and seems to spread the weight evenly where the tire meets the ground. If you travel a lot of paved roads, I'd search for suggestions - seems to me tire pressure would be important for good wear on pavement. If I'm doing a lot of heavy lifting with the FEL, I'll increase the front PSI to around 25 (I think....its written down in the shop and I aint going down there to check!).
