dbaer78
Baby Grand said:I'd guess that if the smaller winch is designed for a smaller tractor, then you may tear it apart using it on a bigger machine if you overload it. I'm not talking about frying the winch, I'm talking about lifting and skidding 9000# with an implement frame which was designed for 3000# max, as you can winch multiple small loads to a landing and then hitch them all up to the winch in one big load to skid out. So if you go with an "undersized" winch, don't overload it and I don't see any real problem.
My thoughts exactly! On the other end to big of a winch can be extremely hard on the 3pt hitch of a tractor. A small winch would be ok if you were ok with not using your tractor to its fullest potential. If you don't plan on using the winch excessively i can't see that being a big issue. Good luck! Whatever you choose you will be amazed what they can do.
