Bullwinkle123
Platinum Member
So I had a big driveway washout. Ordered a truck of 1.5" crushed with fines. Not high quality stuff, the fines were more like moist dirt. Anyway, it was warm enough when delivered but I knew cold weather (as in, in the teens) was coming the next night. Did what I could.
Two days later I resumed work, but the pile was frozen solid to a depth of at least 8 inches. For a long while I could barely get any gravel off the pile. LA1065 loader meets immovable object. Being mindful of not breaking my hydraulic cylinders, I tried various maneuvers to dislodge material. Also tried scraping with the loader, top down, bottom up, back to front, front to back, you name it.
Of course even when I got a chunk off the pile, it was like a piece of cement. I would use the bucket edge to slice down into it and split it up, or run over it with my tires. More dubious solutions.
If there's secrets I should know about dealing with frozen gravel I would love to hear it. I don't consider my work a success by any means and I have half a pile left I'd like to access, preferably before spring. Ideally tips that use the bucket since my forks are in a hard to reach place while snow is on the ground. Maybe forks are the way to go, to loosen up the pile first. I'm guessing they're less likely to balk with more pressure on smaller areas.
