V65ozzie
Bronze Member
A friend of mine has 5 trailers on rental. Only one is dual and the rears are wearing regularly simply because most vehicles hitches are too low for that particular dual HD trailer. In fact I often see it pull away with the rear tires either in the air or skipping along. Naturally on every turn the rears scrub sideways. It had been special ordered to carry heavy compact loads. (cases of soft drinks) Due to rentals he simply can not custom fit each and every client with suitable matching hitches, generally they already have their own installed setup.
On 3/4 ton P.U.'s it is fine but behind a typical SUV it always leaves with the rear end sticking up high.
He needs to add some adjustable hitches to his inventory, I carry 3, I rent them for 4 bucks, with a trailer rental. I believe I got them from harbor freight, loose, sloppy, but cheap, and they have a good tow rating. Saves a lot of wear and tear on my trailer tires.
Right now I'm re-cambering a 5x10 trailer, replaced the axle last year, myself, so I know it was done right, I even welded the mounts. It's a 3500lb axle, tube type, but it gets loaded heavy, so no surprise.
