B52FXR
2014 LS G3033 will not operate in forward position unless I hold it manually by hand. If I am going up a slight incline or pulling in forward range it does ok. Reverse works great. The detent ball falls in place as advertised in F/N/R detents. New Holland dealer thinks the shifting fork is bent a little. Do I have to separate the engine/transmission/rear diff to fix or troubleshoot this defect. It worked great until it went to North or South Carolina for a recall. When I got it back it would sometimes kick out of forward range and has finally gotten to the point of having to hold more and more pressure on the dash shift lever to keep moving forward. I wish I had taken it back to be looked at when I first got it back, but....I didn't. I love this little tractor, but I am getting to where I don't have enough hands and feet to operate this tractor doing anything going forward. I guess I could mount the seat backwards and learn to drive it that way... kinda like the difference between backhoe/excavator settings in our excavators selector lever. Thank you in advance for any kind of help. New Holland said they could fix it for about $2,000 - $2500, but I have a bit of mechanical aptitude and believe I can do it myself with the parts needed to repair my tractor. Did I mention it grinds every time I have to re-engage the lever????? before it goes back into forward range?????
