Diesel Trout
- Joined
- Feb 18, 2019
- Messages
- 19
- Tractor
- LS XR 4145 shuttle
New member here. I am closing on 7 acres outside of Buhl, ID. 2 Acres flat, 4.75 at a bit of a slope. And then steep to a creek. All open, except for trees by the
creek. This was all pasture for the last 50+ years. I will need a compact tractor to brush hog, dig water lines, and dig sewer lines for a septic, etc...
So, I will be getting a compact tractor in the 35 - 40 HP range, with a backhoe, and a 6 ft brushhog, and somesort of a posthole digger.( for fencing and whatnot)
Please explain the 400 lb difference between the 2. Looks like the wheelbase and width are different.... I know the specs are different between the FEL and the
backhoes, but, what about the 400 lbs? Is the front axle bigger? I know it is on the 4100 series. The wheels and tires appear to be the same. The FEL weight dif-
ference is not significant. FEL width is the same. Also, I am curious about the bucket differences between the two backhoes?? IE- Does one have removable teeth-
vs - the other having welded on teeth ?? The XR has larger width avl buckets than the XG.
Thanks to everyone on this site for your experience, knowledge, and sharing..... I have decided on a LG because it appears to be the most bang for the buck, and
my local dealer has a ton of experience in the industry as a whole. 20+ years working for John Deere... Services the local dairy industry, which is huge, by the way. He does not have a ton of inventory, though. NO XR's... There is mostly big AG around here, not a lot of smaller operations.
EDIT: Both models are open-station , and hydrostat
