If it’s a VE pump, the front seal is a known weak spot..
If it’s an injector, it’ll be flooding the cylinder with fuel and the engine will be black smoking like a freight train..
If your system has a supply/lift/feed pump that’s bolted to the side of the engine and runs off a cam.. u could check there.. they have a diaphragm that can rupture and put fuel in the oil..
