The reference was to CUT and utility sized ag tractors. While I never purposely "lug" an engine as described here, I often just use the foot throttle since the work is light and there is no chance of lugging in the obvious sense. But should I be doing this?
Should I instead set the hand throttle at a higher RPM even though I have no need for the power created? Are there degrees of unintentional lugging even though it does not appear that I am "lugging" in the textbook sence?
Using the foot throttle is fine, as long as you're aware of the load on the engine and the rpm. Seat-of-the-pants feel is the best way I can describe it.
The type of transmission plays a role as well, with an HST trans you may be better off using the hand throttle, in fact I don't think too many HST tractors even have a foot throttle??
I occasionally use the hand throttle while brush hogging, but only if I'm doing long unbroken loops. My tractor is traditional gear trans, with clutch. I don't like engaging or disengaging the clutch with the engine above idle if I can help it, to avoid any extra wear and tear on the clutches. If I'm in a stretch of heavy cutting, I try to keep the PTO rpm close to 540 to get better results from the mower, and I try not to cut much below 2000 rpm on the tach at any time. With mine, 540 PTO speed equates to about 2350 engine rpm. I engage the PTO at idle, let the clutch out to start the PTO turning, then the drive clutch. As I start into a cut, I'm close to the 540 PTO rpm.
Diesels are a pretty tough engine, using the majority of the available rpm range won't cause you any grief. Most PTO driven implements work best at their designed speed of 540 rpm, post hole diggers being the first exception that comes to mind. Trying to dig a post hole at 540 rpm can get exciting in a hurry. I'm usually at idle or just above it when using the PHD, if the engine seems to be labouring I increase the speed until it smooths out. Again, seat-of-the-pants feel.
Diesels are happiest working at about 80 % of the rated power output in the middle of their torque curve, this will keep carbon buildup to a minimum, prevent ring and cylinder glazing, etc.
For most of us that isn't possible, the highest load I see is usually brush hogging or snow removal.
Still, with proper engine design they are almost "idiot proof" as far as operation is concerned. There will always be a few people who will have problems, usually those who think that letting it idle overnight is a good idea, or that they have to run at max rpm no matter what they're doing.
Like most things in life, moderation is the key to success over the long term.
My personal opinion, obviously !!
Sean
