Big_Cajun
Greetings!
I'm brand new to the site and was hoping that some of you could steer me in the right direction. I currently take care of 64 acres of land that consists of hardwood forest, fallow fields (with about 10 billion chinese tallow triees, aka. chicken trees), and some of which can get really boggy during the late winter.
I must note that I am almost finished refurbishing a MF 1130 diesel with an 8' JD blade on the front end. I plan on using this big boy to do some tallow tree removal (which of course, will be followed with an application of 2,4-D). With that being said, as soon as the scrub situation is manageable, I'd like to use an M series tractor for upkeep, a bit of organic farming, and some haying applications.
Not all 64 acres will be shredded using the smaller tractor, but I know I need an Ag tractor and not a compact.
I've all but made up my mind on the 4x4 M-series Kubota. I'll have to add a FEL later on due to cost constraints. Would anybody be able to give me a ballpark of what the M4900 or M5700 would cost set up like I've explained?
One more thing: I'm 6'4" and weigh in at about 340lbs. As you can see, most tractors aren't ergonomically suitable for a fellow with my dimensions. I've tried out an M4900 and a JD 03 series and I seem to be pretty comfortable on both (me on an L4400 looked like Bigfoot on a Tonka truck). Are there any other makes that would fit me a little better? I can rule out MF 400 series...kinda small.
Thanks in advance for the help guys!
BC
BC
