M5140 vs. M6040
   / M5140 vs. M6040 #11
The V2403 has a good track record and is used in the MX4700 and MX5100 only without the turbo on the MX4700. The only difference I saw was the M5140 has an organic main clutch and the M6040 has Ceramatalic; wish I was smart enough to know whether that's important or not, but I kind of like it anyway.
As mentioned by ovrszd, the M6040 appears to come with larger tires. I like big tires and so does my dealer, so he orders all M8540 with the same tires as the M9540, if not, like ovrszd I would have an M9540 as opposed to our M8540.
While draft control is not necessary for most of us, I have had to change my opinion on it a bit. I used it farming, but not doing utility work. Since going with a much bigger box scrapper, I use it on our M8540 and kind of wish I had it on our L5740, not a real big deal, but a nice to have at least for me.
Not trying to change your mind, just throwing things out there.
   / M5140 vs. M6040 #12
Ceramic clutches are more durable than the regular clutch. They can take more heat and not warp, and also withstand more wear.
   / M5140 vs. M6040
A few days ago,the dealer delivered to me a new M5140HD, , Hyd. Shuttle, ROPS, FEL, Loaded R4 Tires, Canoply, and 6' Land Pride cutter. When I first looked at it at the dealer, they were unloading it off of the truck. It was freshly made in Nov. of this year. I really like to buy something that has not been on the lot for several months. When I first went to the dealer, I asked about the M6040HD and they said it was not a popular tractor, and usually, for a little more money, people would just go to the M7040HD. There is about a $1600 jump between the M models. eg. M5140, M6040, M7040. As far as tire size is concerned, the M5140 and the M6040 have the same R4 tires. And the clutch is Wet Disk and not dry. If I were using a turning plow, I would sure have opt'd for the draft control. Back in 1985, I paid $350 extra to get draft on the L2550, but in all those years, I never used it even once. Anyway, that's my story and I really appreciate all the good comments that you have offered. It's nice to have some good opinions from knowledgeable people. Thank You and Happy New Year!
   / M5140 vs. M6040 #14
Thanks for the information.
   / M5140 vs. M6040 #15
Only the models with the hydraulic shuttle have a 'wet clutch.' The rest use a standard clutch.
   / M5140 vs. M6040 #16
Generally speaking, the smaller HP tractor in the same chassis is the best buy for the money. Generally speaking the $1500-$2000 to jump up the HP seems very expensive.
I
In my current tractor the M8540 and M9540 share the same identical engine. The 10 HP difference is gained in fuel delivery. The M9540 has a size larger tire, front and rear. The tire size drove my decision more than the HP. I was buying a tractor sitting on the dealer's lot and a discontinued model. I could only find a M9540 equipped as I needed so I didn't have much of an option. Later I heard of buyers that went for the M8540 with the larger M9540 tires installed.
You could put any option tire on available on the M8540 I opted for the Radials 12.4 x 24 Front 18.4x30's over the Bias Plies the dealer said they would have put a different tire on the tractor but i figure for $750 what the heck get the radials. I purchased a 2011 because i really did not want the added cost or frustration later down the road with a Tier 4. Mechanical Injection is so much simpler
   / M5140 vs. M6040 #17
Yes, you can get different tires and such on the M8540, now M8560. I wanted cast centers, air ride seat, quick coupler for FEL and a couple of other things but it was going to take several weeks to configure it the way I would have liked. My old tractor was toes up and I needed a replacement ASAP, so I took as close to as I wanted as I could get. If a person has the time, wait and get what you want that's what I did on my L5740.
   / M5140 vs. M6040 #18
Sounds like the $1600 upgrade was not cost effective for you. If you don't need the HP, I would certainly agree. As I said, generally speaking, the smaller HP version of identical chassis is usually the best bang for the buck. Good luck with your new tractor when ya get it!!!
   / M5140 vs. M6040 #19
I had a M5040 you will be very happy with the M5140, post some pics..
