rustydollar
I checked the points and when open the cutoff post has no continuity to ground so they do break. I checked the gap and it seemed a little tight so I recapped them. I then hooked everything back up and tested the cutoff post and sure enough there was continuity to ground again. I disconnected the coil and the wire to the points and the ground wire is shorted, no resistance. From the spark plug terminal to either the ground or points wire is open, no continuity at all. It is a Zico X5700B coil. Am I correct that this is a bad coil?
Disconnect the wire connected to the outside terminal, keep the lose end away from the terminal. Crank your machine over now and see if there is spark, or if you go the route to start the engine and she fires up you can stop the engine by grounding that terminal with a screw driver.
Testing your coil maybe a futile effort unless your sure which coil is being tested, inside the main coil there are primary and secondary coils, the latter coil produces the high voltage spark supplied to the spark plug.
Some magnetos came equipped with a kill button, shown below.
