Hi folks, I'm looking for a little help. I have a 2012 Mahindra Max 22 with 490 hours. Only problem before my current issue was a bad fuel shut off solenoid in 2015. The problem I'm experiencing is that when I turn the ignition switch to warm up, the tractor it goes through the usual chattering then a click and the glow plug and battery indicators illuminate. At this point I used to go to start and the solenoid would engage and the engine would turn over. Now I get the solenoid click but the starter doesn't start and I hear some relay chatter and the battery light goes out and the glow plug indicator goes dim - about half of normal intensity. Some additional data, when the key is off I have 12.8 volts at F1 and F2 nothing at F3-F6, battery is 12.8 v. When I place key in warm up voltage is 12.5 volts at F1-F6.
Another observation is if I try to start again in quick succession to the first attempt I see the following: Key off F1-F2 12.8 volts F3-F6, 0 volts (battery 12.8 v). Key on warm up F1-F6, 4.5 volts glow plug indicator dim, battery indicator off, (battery still 12.8v)
A little recent history, battery died over summer so it was replaced with a new battery which worked great until the recent problem. I am pretty knowledgeable with ICE engines but not great with diesel (but I want to learn). I have a background in electronics/electrical work but am now retired.
Any help/suggestions would be greatly appreciated.
