Kerrigan244
New to the forums, so I have a Massey 1528 hydrostatic trans, I was bush hogging and drive it into a sizable hole. After removing tractor from the hole the front axle rear mount had broken off front the frame taps. In the grand scheme of things this is not the biggest problem.
After a more in depth look both the front axle pinion and the 4wd output shaft have sheared off the splines... I知 not to worried about the axle pinion. The biggest problem is fixing the 4wd output shaft in the transmission. If anyone has taken this on any advice would be great as fare as removal. I was able to download the service repair manual but it doesn稚 clearly or in any type of depth explain how this should be done.
