texasjohn
Super Member
I'm up on my roof annually putting caulk on hex head screws that have backed out and they are in the flats..causing multiple leaks all thru the house. I have traveled to central america and noticed there on a BUNCH of metal roofs that EVERY ONE was screwed on the ribs..and they get LOTS of rain there.... daily, year round.
My conclusion: The recommendation to screw on the flats is because this is easier to install and will not deform the metal. This allows for inept and careless installers and less install cost. Initial appearance is good and short screws cost less. It works for about 10 years, then problems begin (my case) and when you go to the builder, they mumble about having followed manufacturer instructions, and you are left on your own.
Final conclusion... physics says that if you install on the ribs with long screws then even if a screw backs out, the resulting metal penetration hole filled by loose screw allows only extremely small amounts of water to enter during rainstorm. Water runs downhill and thus quickly leaves the penetration hole. However, on a flat, the same hole allows a torrent of running water in. Trust me, I know:drool:
Personally, I can't see how screwing on the ribs ever creates more risk of problems over the years than on the flats.
