Ok I'm trying to figure out what all parts I will need to buy. I've got a friend that is going to help me replace the clutch. I've never worked on the tractor other than fluid changes etc.. but I have been inside several motorcycle engines. I went to agcopartsbook and found the part number for the clutch disc - 3703735M92 Item number 1.
I looked up this part number and found cross referenced kits with part number M3703705NU that comes with a new pressure plate, disc, and hub for around $350. Is that all that I need to buy? Any other bushings / gaskets / seals etc I should replace while I have it split? Also I found a new clutch disc for under $100. Would it be foolish to just replace the disc?
Also since I got the tractor (2nd owner) I noticed that there is a small leak coming from under the tractor. I'm not sure what the tube is (probably a drive shaft - about 2" diameter). It exits the bottom of the transmission case. Both ends appear to leak a few small drops each while parked. I can't tell if the fluid is dirty hydraulic oil or dirty motor oil. There isn't enough to really tell. I figure I should fix this while I'm working on it. What exactly is this tube so I can find the right o-rings / seals needed to fix the leak.
Thanks
