radrock
Veteran Member
- Joined
- Dec 22, 2011
- Messages
- 1,466
- Location
- S/O Joplin, Missouri
- Tractor
- Massey Ferguson 1526 Hydrostat
That's a nice setup. Although the turf tires are nice. I feel I would get the traction tread because I'd mostly be using it to clear brush and bushhog. Do you use your FEL as a balast while you got the hog on the back?
I already deleted that last post haha. The R4 tires on mine are rather a flat surface and don't tear up the grass unless really wet. The turf tires would not work for me here. Actually I take the FEL off when I mow. I enjoy it a lot! The tractor gets around real good without it and I don't have a stablity problem at all. and like I said I do not have loaded tires. I trim with the zero turn (or my son does) You have to look at it this way. When you are mowing with the Mower on back you are mostly draging it so there is not that much weight on the back, so without the loader, you are pulling the mower and the tractor is pretty well balanced. With the loader on and draging the mower it will be front heavy when going downhill. That is not a problem unless you are leaning as well (which I have some places like that).
