kissyface
is there an easy way to get the rear wheel
off a tractor on your own
With the wheels on the ground and the tranny in 1st gear, remove the topmost lug and replace it with a stud about 3" long (a spare lug with the hex head cut off). This will prevent the wheel from toppling over on you while you remove the remaining lugs. Jack up the tractor so the wheel is free to move. Then carefully rock the wheel back a forth a little to walk the wheel off the stud. If the tire is filled with fluid, I advise draining it before removing the wheel. Just take your time and be careful while rolling the wheel around your shop.
Good luck
