Here are some pics and a link to a video of the first tests. I guess the results are mixed - yes, it will build 5 psig boost at full rack under load so I suppose I accomplished what I was looking to do. I was hoping to do this more in the 2000-2500 rpm range but I'll take what I can get. Bottom line, in my opinion, is the turbo still appears to be too big and/or the turbine wheels are incorrect not that I expected it to be perfect, especially with this "trial-and-error" method I chose. I'm going to leave it on but I still have a lot to do before it's finished:
1.) The intake hose is resting on the exhaust manifold so I'll need to hard pipe it over or reroute the hose, or a different one. This will eventually require making a cut-out in the hood so it will close properly.
2.) Definately need something more robust for the oil supply and returns
3.) Need to install the intake filter and exhaust pipe (first task)
4.) Mount the boost gauge
5.) Paint up the piping
6.) Other things I can't think of right now (oh yeah, a turbo sticker in the end
For clarification, the video shows the tractor in 6th gear with the brake on and me letting out the clutch to put the engine under load to build boost.
VZ21 KE75 first run - YouTube
