ponytug
Super Member
While I wouldn't advocate removing a lovejoy coupler if you have one, there are new motors from Eaton and others that have the motor with built in shock absorption. (something about oil suspension and shock dissipation by design) I have no idea how effective the design is, but clearly the manufacturers think it improves the motor reliability. According to Terry, the 72" brush cutter on the 1445 is this design.
If you do put in a lovejoy, make sure that the two motor axis are aligned, and stay that way. Mis-alignment is the #1 cause of lovejoy coupler failures, and it can happen very rapidly. Bear in mind that it may be advantageous to reinforce the deck around the motor and coupling to get a stiff enough plate to align everything and keep it that way. Belts have the advantage that they do offer some shock absorption, jam protection, and reduce the alignment requirements enormously. They also open up your choice of hydraulic motors, because you can alter the pulley sizes to get the blade speed that you desire from any given motor speed.
I think that the engineering tradeoffs are complicated; clearly the existing design failed under your conditions. That at a minimum presents the question of whether direct replacement is the best thing for you. As they say, YMMV.
[Off thread comment:]
All the best,
Peter
For those with curious minds, there is an interesting article on how an established computer graphics chip company made a connected series of engineering choices that has caused them widespread grief. I take it as a lesson of why wearing a belt and suspenders is sometimes a good idea, and a useful lesson on why it is a good idea not to lose sight of the big picture.
All the best,
Peter
Mith, the deck mounted hydraulic motor that came on my 48" brush cutter was a re-branded M+S Hydraulic MLHR 50 wheel motor. M+S Hydraulic is a Bulgarian company. The motor seized, and I replaced it with a Parker TJ0050US080AAAA wheel motor, which has roughly the same specs. The Parker was built to order for me. Nobody had them in stock.
I strongly suggest you do not directly deck mount the motor, as Power Trac is now doing with the 48" brush cutter. In my opinion, the shock loading is what caused my motor to fail very early in life. The older models have a different motor mounted on a bracket. The motor is coupled to a blade hub by a Lovejoy coupler. It provides at least some isolation from shock loads. The variant I have has none.
It is easy to find straight shaft motors of the right size for the old style brush cutters. It is very difficult to find tapered shaft wheel motors for the current models, other than the M+S model that failed, which is quite expensive. The Parker was much cheaper, but must be built to order, and most US suppliers don't catalog it.
I did not want to go with a larger displacement wheel motor, which are much more readily available, as it would have produced unacceptably slow blade speeds.
