AKfish
Super Member
- Joined
- Oct 1, 2004
- Messages
- 5,417
- Location
- Alaska
- Tractor
- JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
Mine is the shuttle shift and I can only assume that it was some sort of lack of use issue with the electronic switch because once I started using it more it quit doing it, so I hope it continues to work, if not I will tackle that project. As far as spring goes I'm still feeding cows hay, it is so dry here that my pasture can't come out, so I'm waiting and praying for rain. How's it going in Alaska?
Glad to hear the tractor has been workin'! Still cold here. Minus 2F here this morning then it warmed up to 32F and the snow on the shed roofs started melting.
Spring is slowly moving and there's still more than 2 feet of snow on our pastures. Likely be the end of May before I can get fertilizer on the hay fields.
Sorry to hear you're so dry down there... Seems like you folk's either have way too much water - hurricane - or too little!
