The Fred
Veteran Member
I believe there is a crankcase breather valve on the valve cover. There is a hose from this valve to the intake manifold. I am assuming your engine is fairly similar to my L5740. The workshop manual doesn't illustrate the valve very well - there is a top view showing 4 attaching screws holding a cover that might access the valve. On my tractor I can barely see the hose because of 2 tanks covering it. Back in the 60's when they first started putting PVC valves on cars my dad bought a car where the corresponding valve tended to freeze in cold weather and blew out the valve cover gasket a couple times before they came out with a fix. This sounds like what is happening to yours. And yes, PVC is new to many off highway diesels. Tier 3 engines I worked with still had an open breather tube - just an open hose that directed the fumes down and out. Your 2012 tractor under 75 HP is Tier 4 interim and I believe PVC became required. The only older diesel I still have is a 2005 mini-excavator with a straight out hose and the crankcase fumes from that little engine are quite impressive, and smelly. It sounds like Kubota has a problem with their valve that cropped up due to this odd winter.
Just to the right of the beer bottle, 4 screws, remove carefully because there is a diaphragm and small spring underneath. Most likely it froze there. Good luck! Fred
