gemini5362 said:
The ones I was talking about have 400 amp hours.
The idea of making a full wave rectifier circuit was a joke. (I Need to remember to put that disclaimer in there).
I would have just taken and made the device put an 1 amp fast blow in the primary circuit put a large current zener across the outpout and crossed my fingers
Wow, I had no idea you could get 400 amp hours or even way more in one of those little jump paks!!!
My diesel starting batteries are big heavy honkers and weigh a lot and only have 100 AH each. What battery technology are they putting in those things?
I assume there is a large unstated humor disclaimer attached to both the fast blow fuse and the zener!
Please accept my humor disclaimer regarding the comments about size of the jump pak batt and question about batt technology.
Serious comment follows: Those little hand held jump paks DO NOT HAVE 400 amp hour batteries! I was relatively ignorant regarding jump paks, never having owned one but I am not entirely ignorant regarding battery technology and energy density afforded by same. I looked up a couple representative jump paks and found one by Black and Decker rated for 300 amps which has a 9 amp hour battery.
I found a HD pak capable of starting big rig diesels for $289 which has a peak output capability of 2000 amps but it is powered by a 34 AMP Hour sealed lead acid battery!
A brief review of amp hours. Amp hour ratings are standardized as 20 hour ratings, i.e. a 100 amp hour battery will supply 5 amps for 20 hours. Unfortunately there are reciprocity effects with many battery technologies, including lead acid, and the faster you take out the energy the less you get in total. No way will a 100 AH battery give you 100 amps for an hour.
So what about the 9 AH battery in the B&D jump pak rated for 300 amps? To make the math simple lets say it has 10 amp hours. Then you can get 1/2 of an amp for 20 hours. It will not give you 10 amps for an hour. It will not even give you an amp for 10 hours. If you put a 10 amp load on it (subject pump) then it will be asked to provide 20 times as much current as the amp hour rating. It will NOT give you 10 amps for more than a few minutes before it discharges sufficiently to lose pumping power. Current supplied will drop well below 10 amps rather quickly.
I would not suggest this as a method of pumping very many gallons of fuel at a time. The $289 version with its 34 amp hour battery would work better but would likely be marginal at best filling or emptying a drum.
Being ignorant of the jump paks I had to do a little research to get the facts but they confirmed my suspicions. The little cheap paks do not have enough amp hours to do a good job of running a pump to transfer meaningful quantities of fuel. Recovery time is likely an extended period so pumping a few gal and waiting for it to recharge to pump a few more gal is not something I would recommend.
I stick with the battery charger suggestion. I still may buy a jump pak for all the conveniences mentioned but NOT for running a pump to transfer fuel.
Thomas, thanks for instigating my look at jump paks. I'll probably be getting one of those.
Pat
