inveresk
Platinum Member
beenthere said:Not as I understand it.
I think the condensation is on the inside of the door caused by the outside cold temp and the moisture-laden inside air.
Outside cold air holds very little moisture, thus the reason the Relative Humidity of cold outside air is usually quite high. Inside warm air holds a lot of moisture and thus condenses when hitting the cold air that can't hold any more moisture.
Beenthere, I have one of those inside/outside weather stations. Outside sensor is under an overhang outside my office 80 feet away. Inside sensor sits on a Maple cabinet in the sitting room. It's a clear night, starry sky, outside temp 0oC and RH is 89%. inside air temp is 22oC and RH is 33%. Inside RH will increase by morning once the log stove dies but will be no more than 50%, a lot drier than outside air.
