kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,910
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
I bought this nearly new '13 Z71 last Memorial Day and have since had some time to do a few things to it..... First, I had a Rough Country 3.5" lift kit installed. The next thing was a set of nice chrome rims that I got off of craigslist. Then had some Falken WildPeak 285-65-18 tires mounted on them. Then I bought some stainless steel 3" step rails to make it easier to get in the cab.
The next step was to get a set of Bushwhacker pocket fender flares on order, then get them painted to match the factory paint. Had to remove the Z71 decals because the flares would partially cover them up. May order some new decals off the internet one day. The only other thing I have done to it up to this point is to order a Range V8 AFM disable module. This is a little cheater box you can get to disable the AFM on these 5.3L engines.
After I had bought the truck, I found out that the 5.3L engines had been having an oil consumption issue. Not every engine has this problem, and GMC has done some fixes for it, but there is still no solid evidence to show that the problem has been fixed in the 13 year models. From what I have read, it seem that the cylinders that have the oil consumption issue are the ones that get switched off when it's in V4 mode. The Range V8 simply disables the V4 mode fulltime, as long as it's installed in the diagnostic port. You don't get anymore HP, but it runs better and shifts smoother all the time because it never goes into V4 mode now. Hopefully, this will keep my engine from ever experiencing the oil consumption issue!
Anyway, that's about it for now. I do have a chrome bug shield sitting in the garage that I just ordered and have yet to install. After that, I might get a stainless bull bar to go on the front. Eventually, I will get a spray in bed liner, but that can wait awhile. That should about do it!!
