Just Bob
Bronze Member
I need some wisdom - I'm new to this stuff. My new to me L275 was bought for its front mounted snowblower and heated Sims cab. While going through doing a full service and check-out routine I found a broken turnbuckle that connected the left side arm of the 3 point hitch lift arm to a small lever on the left side of the hydraulics/transmission case - about opposite of the position control lever on the right side of the case.
Googling around best I can determine is it is a "neutral return lever". Messing around with tools it appears the small lever on the case is frozen up and this caused the turnbuckle linkage to fail. The 3 point hitch raises and lowers fine.
My questions... Of course, what is it? Can I use a 3 point implement (specifically a scraper blade for snow) with this being inoperative? Easy or hard fix?
Many thanks in advance.
