mikedodd
- Joined
- Nov 6, 2011
- Messages
- 27
- Tractor
- Kubota BX2360
I have a stand-alone 6KW generator powered by a Yanmar engine model L100V6EA1C1AA (Engine Number: M29254). It has worked fine since 2013, but now the 15-amp fuse between the battery and the ignition switch and regulator blows instantly when the key is turned to Ignition.
I traced-out the wiring diagram, and it appears the green wire from the switch to the regulator is shorted to ground. This wire is labeled IGN on the wiring diagram in my yanmar service manual.
Two pages in my service manual show two different Regulator numbers: RS5112 and RS2190. The RS5112 wiring diagram shows five wires to the regulator, and the colors are nearly identical to the wires on my regulator. The page with the RS2190 shows only four wires with different colors. It appears that one wire (yellow) from the regulator is for the Charge lamp (which i don't care about).
Question: I can not find an RSS5112 regulator to buy, but i see lots of other Yanmar regulators. Are these all pretty much the same? What differences are there? Charging current? Could i replace my RSS5112 with a different part? If so, what should I look for?
Thanks in advance for any and all advice.
--- Mike
--- Mike
