hello all, any help would be appreciated. i needed to start my tratcor in about 28 degrees f. I have never had a problem with this tractor, but i don't run it much in snow/winter at all, a few times. i heated the glow plug(s)? not sure how many, its a 3 cylinder diesel mitsubishi i believe. it cranked fine but would not start,there was smoke from exhaust, i tried until the battery died and i put it on the charger. went to the store to get diesel starting fluid, got back and it started without fluid. i needed to start it again a couple days later, same problem, i gave it a spray before the battery died again, and it started right up,ran fine.. ran it for 20 -30 min, shut it down. then a couple days later i needed it again ,same problem, little spray, runs like new. it has good compression, it's getting fuel, (smoke from exhaust) sounds like it's cranking hard. It is much warmer outside now and it will not start without a squirt of spray. I have started it 3 or 4 times total with a tiny amount of spray, i ran it for 45 min last night, sounds great, i was able to shut it off then go back out after a half hour...it started right up,no spray... then i waited an hour...started right up. went out today, no start ...just cranking and light colored smoke. i did put winterizing additive in it. maybe too much? could it be the battery??? it cranks hard but loses cranking speed about 30 sec of cranking. will this model not start if it has a bad glow plug? its possible that i use the glow plug a lot in warm weather. if there was air in the fuel lines it would not run for 45 min.,correct ? oil is right, i changed the oil and all filters last fall, then ran it a lot. oil level,coolant, hydraulic fluids are fine. it has 250 hours.Any advice, or help would be greatly appreciated, thanks
