I've heated with wood now for 2 winters and the deal was I split it by hand for 2 years then I could buy a splitter!
I found this on craigslist and bought it.
All it supposedly needed was new hoses. When I got home in replaced all the hoses and new fluid. It works and the cycle time was good but there isn't enough pressure to split wood. Put a hydraulic gauge on the pressure side of the pump but only saw 1000psi at 540 pto rpm. I have no idea what the hydraulic pump is from and neither does the guy I bought I from. Its got some casting numbers but Google comes up with nothing.
What should I do next? Rebuild this pump? Who does that? Buy a new pump? Which one and from where?
I like using a pump mounted to the unit but could I do that with a regular pto pump?
Thanks for then help.
