Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,660
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
I don't know this tractor. Some times you have to replace cylinder bolts because they are stretched an don't torque right. Also make sure the bolt holes in the block are clean ( blow out ).
If cylinder linings are replaceable, the seal under one might leak. (then it shows coolant in the engine oil as well).
And for sure you do not want coolant in the oil; that could render the engine into a boat anchor.
