To the best of my ability, today I located and ran a string line 6' off the property line. By connecting the dots...so to speak...I was able to determine where the missing pin would land in the corner....not the exact corner point mind you, just the boundary line along his driveway. I checked and rechecked several times and believe I'm within an inch or 2 of where it should be. But that's using a masons line covering 400'+ in length and it's pulled tight enough to play the violin. I used 6' as a reference to clear the existing tree line and then measured back to locate a 3' mark away from the boundary line.
Well...somethings odd for sure. According to my measurements, the tree line at his corner where the pin is missing is exactly on the money. The trees are exactly where I want them...3' off the boundary. As you move away from this corner to the opposite corner, the tree line moves closer to the boundary line. At the corner with the existing mature trees, their 8-9" away from the boundary as I already knew. Going by memory of where the missing pin should be at his corner and sighting the tree line from there, it appears the trees are 3' +/- off the line and that agrees with my measurements. Not sure what to think now and can't quite figure it out. I do know I told my tree guy to follow the existing mature Arb's when he planted the new ones. Even though my measurements show the tree line to be running at an angle, if you sight the line versus my neighbors driveway, everything appears straight. UHH???
No doubt now that I'll be calling the surveyor this week and have her come back and set the corner pin again. Not sure just yet if I should give him the bill and ask to be reimbursed or file in small claims court. Either way he's paying!!
Something else I noticed after looking at different aerial views of the property. His driveway is not straight as an arrow...as i assumed... it veers closer to the boundary line as it approaches the corner point by his house. What this means is all these years when his fence was in place, he had plenty of parking along the blacktop. And it's worth repeating his fence was on my property the entire length by about 6" IIRC. So that leads me to believe he still ~thinks~ he owns a wider area along his driveway than he actually does. And to think the whole point of me doing this is because last spring he asked me to keep the trees trimmed back so he could still have guest parking. Now it appears my trees are not growing across the boundary line at his end.
Make sense? lol I'm doing my best trying to explain. I'll put that aerial view pic back up next post and see if I can edit it with locations
