OP
dieselman1967
- Joined
- Feb 21, 2015
- Messages
- 23
- Location
- McDonough, GA
- Tractor
- 1967 Ford 2000, 1951 John Deere Model A, 1974 Massey Ferguson 150 Diesel
Try shoving that third lever all the way forward...
If I recall, dad's has a detent to hold it forward, in the "normal 3ph operation not using the loader" position, click it back to the middle for loader work, with the 3ph hight control all the way up and draft control lever all the way up to 'constant pumping'.
Keep in mind, dad's is a mf135, which I believe has a lower GPM hydraulic pump (3.5 GPM vs 10 GPM), so the loader vs 3ph prioritization of hydraulic fluid may not be an issue for you.
Play with the levers, both loader and 3ph controls. Hope it works!
I think you are going to be right about the third lever. After further research, it looks like there has to be some type of diverter valve, and that 3rd lever must be it. It even looks different than the other 2. From what I understand, on these older tractor that just have an internal hydraulic pump you can either run the loader or the 3 point, not both of them together. I'll report back after I check it out this evening.
