LarryD
Veteran Member
Glad to hear you found the problem without too much expense.
Does you tractor sit outside? Living in the Pacific NorthWet mine gets a lot of wet but I keep it inside when not in use. I try to keep the pivot points greased (mostly once a month) and use Fluid Film on the non-zirk points. I have to admit I've never sprayed that particular spot however. I wonder if FF would affect the seals?
