MVTractor
Been here before with the same problem, as have many more on this site, pulled wired connections I could get apart used dielectric grease then switched the battery with a known good one, took old tractor battery put in truck and its been fine ever since and the tractor started with the truck battery and has been used several times since. As this appears to be a common problem with this tractor one member suggested replacing the battery cables as they may be in the process of corroding inside and that I might have been able to secure a connection when I was moving the cables around the first time, made good sense to me. it always acts like a weak battery, dim or no lights, starter clicking or nothing, period. This time when I had the issue replaced the neg cable and went through the other connections as before with no change. Thinking I should get the pos cable, as was suggested, but I can't seem to find a replacement for it. I live in a area that makes travel difficult and not having much luck on the net so need some info on part# and best places to order this cable
