Hi all. Quick update. Been running mostly OK for a good week know. Going to attempt the front crank seal replacement tonight. Got all the front end clear - radiator and hydro cooler coil. Fabricating my own pulley puller to get into the tight space. Coolant was looking nasty anyway, so a change is good. Also cooler hoses - all 6" of them on each side, need to be replaced. Thusfar I've run it pretty hard. Mowing in thick grass (like 4' high stuff) and up and down steep inclines (backing up those steep ones), and running a 5' tiller on pretty hard-packed arena soil. Side note: that 5' tiller is just too much for the JD4100 17HP. It's ok in loose soil, but not for my clay. I may try to remove some tines and see if 4' of coverage is workable. I'd should have gotten the 4' tiller, but *thought* the 5' would cover my tracks better. It does, but at 0.001 mph as the penalty. After I adjusted the fan shroud I've had the temp sensor go off once - while tilling - and after a few mins of idle, it was fine. I went back to work again. Not sure what that was about, but as I noted the coolant is pretty dirty, so maybe a flush will help. I'd like to fabricate an entirely new shroud with the offset fan that I have now. As is, there are some gaps around the edge and bottom that don't force the air to pull through the fins.
I also have - since forever - a tiny leak on the hydraulic pump line, the smaller one, right at the pump. Flirting with brazing. We'll see.
Here's to getting the front crank seal replaced tonight.
