Milo
Platinum Member
- Joined
- Aug 7, 2006
- Messages
- 943
- Location
- Preston County, WV
- Tractor
- JD 3520, Ferris Z2100, Kawasaki Mule Pro MX, Honda Pioneer 520
Re: New X310 Now Won't Start. Update, Problem Solved
Problem found. Took it to the dealer and the service person tried starting it only it wouldn't turn over. When he pulled the second spark plug gasoline poured out. (When I'd pulled them no gas came out at all the plugs were just wet) He felt it was the float valve in the carburetor saying he'd seen one before that had a bit of plastic in it not allowing it to seat and close. I suggested it could be the float itself. He said he was ordering a new one (I assumed float valve). Two days later it was ready. He had to take a carburetor off another new tractor because Deere didn't have any of these carburetors in stock and didn't know when they would have them. Anyway it started right up and runs perfectly. When he looked at the removed carburetor he said there was a piece in the casting which the float was sometimes contacting keeping it from raising up and shutting off. I was a little disappointed he didn't change the oil and filter saying the level was fine and he didn't smell gasoline in it. I think I can smell some so I'm changing it myself just to be sure, so the first oil change will be at 2 hours instead of the 8 in the service schedule.
I'm just glad he knew what he was doing and found the problem right away while I was there. I would have bet that it was one of the safety switches. Anyway I'll change the oil now then put my "safety defeat switch jumpers" back in. When I'm mowing I like to turn around and look behind when I'm backing up, not look down on the dash and fumble with raising a switch.
