Texan4Life
I decided to upgrade the engine cooling on my dozer. Hopefully this will prolong the time in between blowing the radiator out. I added and engine oil cooler, and booster engine coolant cooling as well. I used the thermostat by pass ports for the coolant circuit and then used a sandwich oil filter adapter for the engine oil circuit. Even built a little frame for the coolers so it could swing out for easy cleaning. It took longer than i expected but came out well I think. Bonus is the sandwich adapter also converts it to a 3/4-16 thread so now I can run a FL1a style filter. The original was a real odd ball 1-12 and only Baldwin had a cross over for it. So now i have a ton of options in brands/filter media ect.
I used 10 AN hose and fittings to match the original braided lines. Also I wanted to learn how to work with AN since I never have before. After this project I think i'd like to learn how to bend and work with hard line, it would have been a more compact install i think as well as less expensive.
engine oil cooler: Derale # 51010
coolant cooler : Derale # 52510
oil filter sandwich adapter: Perma-Cool #189
