Volfandt
Veteran Member
How to get the best cut possible out of ones machine is a major topic in many threads now, so I thought I'd share mine mowing w/a BX23 and 60" MMM.
Theres several keys to obtaining a great finish cut.
A well tuned tractor, a properly balanced mower and good properly sharpened blades.
These are all necessary but so is operating the machine at the proper pto speed.
With the tractor & mower mechanically sound, the key to a great finish cut = blade tip speed. The faster the blade tip speed, the better the cut.
This is evidenced by the fact that all commercial mowers have much faster blade tip speeds than consumer mowers. I recall reading on several sites that consumer blade tip speeds are regulated to be slower inorder to be safer. I don't know how factual that is, I mean I don't know if a blade tip spinning at 14k fpm being is any safer than one spinning at 15k rpm but thats the logic from what I've read.
In any case blade tip speed is directly purportional to engine rpm, i.e. the faster an engine spins, the faster everything it powers spins, i.e. the pto(s). Simple logic.
Hense, if one requires the best finish cut his machine will produce, one needs to operate the machine at the rated blade tip speed which is achieved by operating at the engine's rated pto speed.
The owners manual provided with my BX23 and RCK60B-22BX MMM provides the necessary data for me to assertain how to operate both at their rated speeds to obtain the best finish cut.
The BX23 is rated @ 3200 rpm to get it's 22hp output.
To obtain 2500 rpm at the mid pto the engine is rated at 3125 rpm.
To obtain the 60" MMM's rated blade tip speed of 14271 FPM (2647 rpm), the engine must be spinning @ 3125 rpm.
If one is powering a 54" MMM with their BX23, a blade tip speed of 14527 FPM (2969 rpm) will be obtained @ 3125 rpm.
A couple things jump out at me when looking at these specs.
1) The BX23 doesn't have to be running at WOT (3200 rpm) inorder to achieve the "rated" blade tip speed. Just a notch or two below full throttle (the 3 O-clock setting) will do.
2) The 54" MMM achieves higher blade tip speeds than the 60". Those that are compareing both can use this as a good indicator that the 54" should produce a slightly better finish cut.
3) Since the BX23 produces the MMM's rated bladed tip speed at less than WOT, it should use less fuel, run cooler, produce less noise and be more durable than a comparable gasoline engine powered mower, be it consumer or residential.
Conclusion, those operating their BX engines's rpm either slower or faster than the rated outputs are not getting the optimal performance out of their tractor and MMM setup.
Course there are many other variables involved, but this is just the "tip" of these nuances
